okey the PC i have at this moment is
Inter Core 2 Quad Q8200 2.3ghz
MS-7592
Nvidia GTX650 1gb OC
2x2gb kingston ram at 1066 or 1333mhz
550W LC Power , SuperSilent LC6550 V2.2B
HDD WD Blue Caviar 500gb 7200
SSD HyperX 3k 240gb
i have ordered the ``Kinston HyperX Genesis 1600 (2x4gb)`` and i been wondering which board to buy for Intel Core i5 4590 BOX???? i dont want to go for OC option what so ever , if u guys know any better option for gaming then 4590 i5 let me know which board and which cpu ... im going to use my old GPU and PSU , same for storage that HDD and SSD ram is going to be that HyperX
i need some good budged board with no OC or CPU and board what solution seems better
thanks in advice
For a motherboard....
Go h81 if you no intention to XFIRE and save some money.
Go H87/H97 (one that supports Xfire) if you want to XFIRE AMD GPUs.
And I'd consider stepping up to a Xeon 1231V3 as it basically a locked i7 with no integrated graphics. http://www.newegg.com/Product/Product.aspx?Item=N82E16819117316&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
PSU Tier List | CoC
Gaming Build | FreeNAS Server
hmm intresting Cpu ... but i was more about for i5 processors the name is name :) if u know what i mean....
now for board i like the price for H81 , even i wanted to do some SLI with one more gtx650....
thanks djdwosk97 i got my answers but i will still wait to see if someone more will post more boards or cpu`s because this cpu i build would be my last i have ever made :)
A Xeon is a locked i7 with no integrated graphics.....
You won't be going SLI on a non Z87/Z97 board (and you shouldn't go SLI with a 650 anyway).
PSU Tier List | CoC
yeah u might be right ... but the problem is that i cant find that xeon that easy here in Serbia, so i choosed the H81 i dont need two GPU`s , my PSU might not handle two GPU`s :) ..... but still the main question is which CPU that is strong fast good for gaming but not that expensive .... i have been looking for that i5 4590 because its non OC .... i have a bad experience with OC
Then get a 4590
PSU Tier List | CoC
i might sound stupid now ... but will all that handle how it should in full power in that order????
Well, a 550w psu is enough for any single gpu config (assuming its able to deliver all 550w on the 12v rail/s); but if it can run your system as it is now, then it will run with an i5.
However, of note, a GTX650 is a pretty weak card these days; so I'd probably want to replace that with something new before upgrading the cpu. Secondly, that PSU is pretty bad....you should probably replace it with something decent/reputable.
PSU Tier List | CoC
i cant go for a card with 100 - 120$ + that is why i got GTX650 .... if my PSU can handle all that as u told , why is bad??? i dont have extra money to get all expensive and powerfull components i did spent 70$ on that PSU
