Intel PC: http://pcpartpicker.com/p/QVBtrH
Note: Case: Sharkoon t28 red edition cannot find anything from sharkoon on the website,
AMD PC: http://pcpartpicker.com/p/WJk33C
So as you can see they both miss a motherboard. that is where i need help... as i don't want to overclock this system i don't need a Z-branded motherboard so could anyone recommend me one? i prefer a red one so it matches my red/black from the other components. and also should i get the CM 212 EVO or just keep the stock one? and last when i pick the AMD one should I keep the FX-8350 or swap it for the FX-6300? and ofcourse the main question which one should i choose because... Intel is on most fronts better with gaming and that i what i want to do. but the AMD one i cheaper. pls help me
Ps, this is going to be my first build
1. Budget & Location
budget: 950 euro and i live in holland 950 euro's is around 1183,23 american dollars.
2. Aim
play the newest games like: the crew, Far cry 4, just cause 3 and lot's more.
3. Monitors
i have one monitor with 1920x1080
4. Peripherals
nope got that all covered
5. Why are you upgrading?
because i need a pc my laptop won't handle the games anymore.
https://linustechtips.com/topic/251733-cant-decide-please-help/
2. Aim
play the newest games like: the crew, Far cry 4, Assasins creed unity and lot's more.
/sarcasm
Nope you need alot more to play Assasins creed unity...
You could ask Ubisoft for some treasure that they dig up
/Sarcasm
ill put something together
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450158
I would say get a 4690k, but if not get a i5 4440 and a h81, AM3+ is dead imo.
The stock cooler should be fine @ stock
Give me a minute ill make you a build
First Build:
Case: Bitfenix Prodigy Black          GPU: MSI R9 270 Gaming@1050/1500         CPU: i5 4570          Motherboard: ASUS H81I Plus          PSU: Corsair CX600          RAM: 8GB Crucial Ballistix Sport XT         Cooling: 230mm Bitfenix Spectre Pro Intake; Corsair AF140 Rear Exuast; 2x120mm Stock Case Fans Top Exuast        Storage: WD Blue 1TB          OS: Windows 8.1 Pro 64 Bit
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450176
Oh shit i thought it was a 4690k in the first place i putted a 212evo in xD well you can scrap that and use the stock if you're not gonna overclock
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450190
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($174.99 @ NCIX US)
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard ($49.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory ($76.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($75.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card ($329.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($32.99 @ NCIX US)
Total: $795.92
Generated by PCPartPicker 2014-11-16 08:30 EST-0500
Only one stick of RAM so you can easily upgrade to 16GB
First Build:
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450191
http://pcpartpicker.com/p/gwDVbv
Changed to the 4690K Which means its OC'able.
Added the Hyper EVO 212
600w Semi-Modular PSU
and 1TB of Storage
also a MSI Gaming MoBo
Added in my opinion a Great Case.
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450192
If you aren't overclocking don't get the K processor.
Edit: FUCK! Nevermind I'm seeing shit.
Do not  as I  do, and  not  as I say. Instead do as you may..
HSS Revenir: CPU=i7 5960x @4.5GHz Heatsink=Corsair H100i MOBO=ROG Rampage 5 RAM=Kingston HyperX Predator 16GB @3000MHz SSD=Corsair Neutron GTX 480GB GPU=R9 295x2 PSU=Corsair AX1500i OS=Windows 7 Ultimate
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450201
and 1TB of Storage
But i'm afraid to overclock :( i don't want to risk it...
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450409
Total: $795.92
Why the EVGA graphic card? I heard that the cooler on it was bad and wans't able to cool
It enough.
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450419
It enough.
You may choose whichever ever cooler you like
It was the cheapest one so..
First Build:
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3450706
There is literally no risk in overclocking.
https://linustechtips.com/topic/251733-cant-decide-please-help/#findComment-3451744
