Not sure what you are trying to say, do you mind rewording? If you're asking what thermal compound to get, don't fret about it too much, the performance difference between compounds is within 5 degrees at most.
He's asking what TIM Linus received a box full of that he showed in one of his videos a few weeks ago.
https://linustechtips.com/topic/25149-thermal-compound/#findComment-318844
It was definitely a box full of ic diamond.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/25149-thermal-compound/#findComment-319450
Just as a quick note, the carat count is just the size of the thermal compound tube, and doesn't affect the actual thermal paste.
Main PC: https://ca.pcpartpicker.com/list/FNsFVY
Secondary PC: https://ca.pcpartpicker.com/list/7sv7xY
Former Intel Response Squad Member, May Class.
Member of the LTT Forums since January 3rd, 2013.
https://linustechtips.com/topic/25149-thermal-compound/#findComment-319582
