Motherboard - MSI X99 SLI Plus
Memory (Ram) - Quad channel DDR4 2300Mhz (16GB)
CPU - Intel core i7 5820k 4.0Ghz
GPU - EVGA Geforce GTX 980 SC (x2 SLI 8x)
PSU - Seasonic 1050W Platinum
Boot device - Samsung Evo SSD 120GB 540Mb/s
CPU Cooler - Corsair H110
Mass storage - Western digital Black 3TB (Not Detected)
Case - Corsair 750D
Network Adapter - Asus PCEAC56 Dual Band PCI-E Adapter. 800Mb/s
OS - Windows 8.1 64bit
Description GPU  - Started Arma 3 To test New Dual EVGA Superclocked 980s in SLI Put settings to Ultra and got 27 ish FPS avg not sure if bad optimization or my setup is having issues I am using 2 Cables to power both gpus with both cables having 2 six pin connectors on them (MY PSU IS 1050W).
Description CPU - My Cpu's Clock speed keeps varying between 1.16Gz to 3.40Ghz Is this intel's Power saving feature? If so where can I disable it. Is it thermal throttling? Any Ideas? Thanks~ post-82959-0-98630600-1416098419.png
(╯°□°)╯︵ ┻━┻            ┬┴┬┴┤ʕ•ᴥ├┬┴┬┴
https://linustechtips.com/topic/251458-gpucpu-problems-new-x99-pc/
Try a different game if you can
The CPU down clocks itself when it isn't doing anything intensive. If you wish you turn this off and only have it down clock when you're idling go into Power Options in the control panel under hardware and sound and change it to performance mode.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
Try only using one of the GPU's.
Then try a different game.
If it's only Arma go into your settings and change something (Forget what it is called, quote this and i'll find it).
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
ik this might sound stupid but did you intstall the new drivers?
Yes I have All The drivers installed.
Arma 3 has bad optimization. try other games out if you want to be sure.
and yes the cpu clocks will go down if no heavy usage....its on the other haswells as well
I have thought about that I only have arma 3 installed at the moment I am waiting for the chance to pull some games from the living room pc.
I have the Power option set to "High performance but it's still doing it?
Try disabling one card and running single GPU and see if performance gets better/worse/same.
Okay Looking forward to your reply.
