so i noticed when im gaming that i get small freezing issues only for about half a second but you notice it. i have only noticed it after amd 14.11 drivers but i think it might be my overclock on the CPU doing it what do you think it is? because i cant see how a GPU driver can cause a game to freeze
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/251309-strange-freezing/
If it is in Battlefield 4 you are playing, that is because they failed at properly implementing Mantle, which makes the game freeze a little bit on some maps when it goes from zero to more than one player near by.
Sorry if my post offended your entire family, but I get kind of defensive when I'm high...
https://linustechtips.com/topic/251309-strange-freezing/#findComment-3444533
Run everything at stock speed and try it again.
About GPU drivers, they can always have some weird issues that can cause some weird things. I think 14.11 is still beta what can expain the issue. Go back to 14.9 if you still have the issue at stock speed.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/251309-strange-freezing/#findComment-3444543
i am running BF4 but im not using the mantle api dont like it makes the game look worse imo
PC PART PICKER
https://linustechtips.com/topic/251309-strange-freezing/#findComment-3444552
What the actual **** are you talking about? It works more then fine for me.....80+ FPS on ultra no freezing with mantle
"I fart in your general direction" -The Frenchmen
https://linustechtips.com/topic/251309-strange-freezing/#findComment-3444599
mantle is not that great in crossfire situations like im in
PC PART PICKER
https://linustechtips.com/topic/251309-strange-freezing/#findComment-3444615
I have to agree. Mantle on BF4 gives higher FPS by a small margin but causes more dips and lags than DX11.2 for me its not worth using (5760x1080p)
In crossfire Mantle on BF4 causes dips and lags in game vs DX11.2 that does not. Also for me the colours look better?
Quack 🦆
https://linustechtips.com/topic/251309-strange-freezing/#findComment-3444654
well that aint the best crossfire config too tbh
CPU: Amd fx 8120 3.9ghz...Motherboard: Asus m5a97 evo R:2.0...RAM: 8gb 1600 kingston hyperx blu...GPU: XFX R9 280x ...CASE: Nzxt h440...
HDD: Kingston adata ssd 500 gigs, wd blue 500gb...PSU: Corsair gs700...Monitors: Asus vk222h Cooler: Noctua nh-d14...Keyboard:coolermaster masterkeys m...Mouse: logitech g300...Headphones: Logitech g430
https://linustechtips.com/topic/251309-strange-freezing/#findComment-3444663
