First build compatibility check, Pls Help
Solved by j.dirona,
Use pcpartpicker for compatibility problems.
^^ this guy knows although there can be problems sometime, example the i5-4670K and the Asus Z87-A Mobo have a weird incompatibility... took me nearly a week to figure out that it was honestly just the two parts didn't work together (it was a lot of returning one board or CPU to get another etc etc.)
