I've got this really annoying noise in my pc, I only noticed it when I moved my pc on my desk after my PSU blew out and I got a new one.
I thought it was just because I moved my pc on my desk but someone pointed out coil whine in one of my other posts and brought it to mind.
I've looked at Linus' video on it and its not as loud as that but you can definitely hear it.
Thanks,
Jem
https://linustechtips.com/topic/251145-coil-whine/
So what's the point of the thread?
Coil whine is cuz of your new psu.
It's caused ethier because of the psu or the gpu, it's harmless i believe, and i don't think there's a way of getting rid of it.
Rig: I5-3570K@4.3Ghz - Cooler Thermaltake Frio Advanced - Ram Kingston 1333Mhz 8gb (2x4) - GPU GTX 970 4GD5T OC - Motherboard Z77MA-G45 - PSU CoolerMaster GX II 750w - Storage WD 500gb HDD - Sound Edifier M3700 5.1 - Headset Corsair Vengeance 1500 - Mouse Razer Deathadder 2013 - Keyboard Razer Anansi - Mousepad Steelseries QcK+ - Xbox 360 Wireless Controller x2
https://linustechtips.com/topic/251145-coil-whine/#findComment-3442466
Ok thanks, I just wanted to make sure it wasn't a wearing fault that would eventually screw everything up, thanks
https://linustechtips.com/topic/251145-coil-whine/#findComment-3442580
