So, i got a new PC and I have been playing some ARMA 3 and ARMA 2 DayZ mods.
But i get really bad fps in them on like high settings. That i'm pretty sure my PC should be able to handle. i know that both of these games are pretty CPU intensive because of bad optimization or something like that but on ARMA 3 king of the hill i'm pretty sure i shouldn't be getting like 10 FPS.
Plus i have all of the latest driver and all of that stuff.
Please don't comment "Oh, why did you get that CPU" or something like that, i know its not a very good choice but i didn't choose it. But it along with a GTX 770 should be able to handle ARMA 3 and dayZ at above 60 Fps right??
Specs:
AMD FX-9590 4.7GHz 8-Core Processor
Corsair H100i 77.0 CFM Liquid CPU Cooler
MSI GeForce GTX 770 2GB TWIN FROZR Video Card
Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard
G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory
Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
NZXT Phantom 410 (Red) ATX Mid Tower Case
Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Asus DRW-24F1ST DVD/CD Writer
https://linustechtips.com/topic/250601-fps-questions/
Specs:
arma 3 has bad rep since it ca have huge viewing areas
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/250601-fps-questions/#findComment-3435593
Out of all the games we usually hear about or play, Arma3 is a pretty intensive resource hungry performance limited kind of game.
No matter what you run it on (mostly)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/250601-fps-questions/#findComment-3435605
Yeah, I guessed that could have been something but it still should be able to handle it right??
A friend of mine with a zotac 770 and a 4770 runs arma 3 on highest at 12-19 fps... So yeah, it's game's fault...
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/250601-fps-questions/#findComment-3435645
