Hi, I am working on a new build for my first ever desktop computer. I am not very well versed at this so any inputs or suggestions will be greatly appreciated.
Build in mind: Intel i5 4460 CPU With MSI B85 Pc Mate
Kingston 1600MHZ 8GB × 1
Toshiba 1TB 7200Rpm
Samsung 24x DvD-Rw
Power Color R9 280 3GB T.D
Deep Cool Gammax 400 CPU Cooler
Sharkoon T28 ATX Case
Thermal Take SE 630w Modular
Will be using this for gaming and some light powerpoint work. Mostly for gaming though.
Cpu: Intel i5 4690k l Mobo: msi z97 pcmate l GPU: MSI Gtx 970 4gb OC l PSU: CM V550 l RAM: RipJaws 8gb l Case: NZXT H440 l Cooling: CM Hyper 212x l Storage: Crucial mx100 128gb ssd l OS: Windows 7 l Keyboard: CM storm quickfire ultimate(Blue) l Mouse: Razor Mamba l Display: Some shitty samsung monitor
https://linustechtips.com/topic/250394-new-build-noob-needs-help/
what about budget,where do you live?
CPU:Intel I5 6700k (4.7GHz)  Mobo:Asus maximus viii hero RAM:HyperX 16GB  GPU:MSI gtx1080 Gaming X
Case:Fractal Design Define S SSD:Kingston 240GB HDD:1TB & 2TB raid 0 PSU:Corsair RMX750 Cooling:H100i v2 OS:Windows 10
Display:Benq GL2440,LG 29" Keyboard:Tesoro Durandal Mouse:Deathadder Sound:2.1 GENESIS NCS-0856, PC-37X, Razer manowar
Hmmmm about 1000sgd? I live in singapore
So that is around £500/$800.
For your budget and first build I think that spec will be fine for gaming.
My Rig!
Case: Corsair Obsidian 650D, Mobo: MSI Z87-GD65 Gaming, CPU: Intel Core i7 4770K (OC'd to 4.2Ghz), RAM: 16GB Corsair Dominator Platinum 2400Mhz, GFX: 2 x Gigabyte GTX770 OC Windforce in SLI, CPU Cooler: Corsair H100i with Corsair SP120 Quiet edition fans, SSD: 2 x 256Gb Samsung 840 Pro in Raid 0, Storage: 2Tb WD Caviar Black, PSU: Corsair AX760i, Monitor: Benq XL2024T Keyboard: Corsair K70, Mouse: Razer Taipan
^that and where are you wanting to buy the parts?
Have you heard of pcpartpicker.com? It's a great way to plan and share potential builds.
I am planning on getting my parts from a local retailer. They charge 10 dollars for the assembly of parts.
Any improvements? I think the gpu can be better. Perhaps an Nvidia alternative? I have a little wiggle room for my budget.
My Rig!
Performance wise? Is it worth the extra? I am sorry I am new at this.
It would be, I use one myself and it will play any game at full HD with no lag, with the RAM though you are better off using 2x 4GB sticks, that way if 1 fails you can still use your computer. The rest of it though looks pretty good though, my computer is very close to what your planning on, when it was built it had:
Core i5 4440
Asus H87M-Pro
1TB Western Digital Blue 7200RPM
2x 4GB Kingston 1333 MHz
Thermaltake Commander MS-I case with a 500W power supply
TI 24x DVD multi recorder
Stock CPU cooler (all you really need on the non K versions of the i series)
Gigabyte GTX 650 Ti 2GB
Apacer multi card reader (cheap and it hates 32GB class 10 cards and transferring more than 1GB at a time)
That cost me just under $1150 Australian Dollars at the start of February. Since then however I've added another 8GB RAM, a Gigabyte G! Gaming GTX 970 (its quiet and doesn't have any coil whine) and a Corsair VS650-650W power supply as the original one didn't have the right connectors. But since your not in Australia you shouldn't get overcharged as much. My GTX 970 cost $565.95 in the cheapest local store, while another one had them at over $670
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
Core i5 4440
Asus H87M-Pro
A gtx 970 costs 450 in singapore. Thanks! Great help. Well i generally expect to play Skyrim with a lot of mods and a full enb retexture mod. Also, I hope to be able to play upcoming titles at smooth frame rates and high settings. Is a 970 good enough?
Skyrim runs at full settings and at full HD so you'll love it, and since they all have 4GB of memory it won't have any problems, unless you go 2K+ for the screen resolution. I just finished a session of Battlefield 4, full HD and graphics with no problems as well so go for it if you can.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
Thank you very much! Great help. Thanks yall!
Can't access the link, could you copy and paste the build? And if your planning on doing video editing/rendering I'd recommend a 6 core i7 as the CPU, since the more cores you have the faster you will be able to get things done, plus your computer would be fine for quite a while before it becomes obsolete.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
PCPartPicker part list: http://pcpartpicker.com/p/bRMFHx
Price breakdown by merchant: http://pcpartpicker.com/p/bRMFHx/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($328.97 @ OutletPC)
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler ($117.99 @ Mac Mall)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($203.99 @ NCIX US)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory ($146.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($119.99 @ Amazon)
Storage: Western Digital Red 6TB 3.5" 5400RPM Internal Hard Drive ($274.99 @ NCIX US)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card (2-Way SLI) ($368.99 @ NCIX US)
Case: Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case ($219.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($64.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($18.61 @ OutletPC)
Case Fan: Corsair CO-9050015-BLED 52.2 CFM 120mm Fan ($10.99 @ Amazon)
Case Fan: Corsair CO-9050017-BLED 66.4 CFM 140mm Fan ($13.98 @ OutletPC)
Other: StartIsBack ($3.00)
Total: $2569.34
Generated by PCPartPicker 2014-11-14 06:15 EST-0500
Toshiba 1TB 7200Rpm
Samsung 24x DvD-Rw
i5 with r9 280 quite difficult for 1000sgd budget leh... i5 with 970 is close to 2k
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
Total: $2569.34
Looking at what your getting, it should be more than sufficient, especially if you ever have a go at overclocking that cpu.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
Thank you. Do you think there is some room to overclock the GPUs too?
Your welcome.
For me, if I was going to overclock the GPU I'd go with a 750W PSU, that way you have plenty of headroom. And if you do overclock, these are the settings I'd recommend as they are easily stable and won't push the cards to their limits:
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
No problem, I hope it all works smoothly for you.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
Total: $2569.34
Not sure you need a Hero over the Ranger? Might save you $40 or so.
You might want a 7200rpm HDD if you plan on running any games off it. Maybe 1x1TB 7200 and 1x5TB 5400 see what price impact that has?
You could go top tier single 980? With the cheaper PSU (look at the Superflower Leadex 650, it will kick EVGA and Corsair to the curb) and Mobo there may be no additional cost.
Also 32GB RAM, check you need that much, some might say you only need 16GB MAX unless you virtual machines?
Thats my two cents.
Also, if you are planning on using it for online gaming with your beast then don't use wireless for it. You need to hard wire to a router.
My Rig!
