So I have a friend's laptop, a Toshiba Satellite C855-1PP here and...
Just now, a message apeared: there's a little red cross on the icon and the message says: "There is a problem with your battery, so your computer might shut down suddenly." "Consider replacing your battery". It has also discharged for almost 10% in 5 minutes now. This only occurred now, in the morning (about 5-6 hours ago) it was working just fine. The laptop is almost 2 years old (not completely sure).
Could this be it? Is the battery dying?!  :(  :(  :(  :(  :(  :(  :(  :(  :(
https://linustechtips.com/topic/249929-laptop-battery-dies/
Chances are that the battery is depleted and can't hold a charge anymore. It will hold for a short amount of time but not a full charge. Consider a battery replacement
https://linustechtips.com/topic/249929-laptop-battery-dies/#findComment-3426931
Battery gauge reset may help.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/249929-laptop-battery-dies/#findComment-3426944
Will a battery gauge help??
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/249929-laptop-battery-dies/#findComment-3426945
