HWMonitor is showing that my SYSTIN temperature is at 86 degrees at idle.
I have no idea what SYSTIN is, tried googling it, nothing definite pops up.
PC keeps crashing after a few minutes playing BF3/BF4, and my northbridge heatsink is pretty hot (but more like 50 degrees, no where near 90.
I'm out of warranty period for my motherboard, any suggestions? maybe ghetto mount a fan? but for that, I'd need to know which component is overheating.
Thanks.
[EDIT]: Actually, the southbridge (which on my motherboard doesn't have a heatsink on) is running hot, hotter than the north bridge (Still not as hot as  90). But still not sure which component is running at that temp. any help?
https://linustechtips.com/topic/249894-motherboard-overheating/
Could you please post your specs (This will help us give you a answer you post is not enough information )
motherboard gpu cpu so on and your case and additional fans if any
The causes are either a BIOS bug causes a high temp reading when it's fine
Poor heatsink application on the Chip set or just poor air flow
see this post for more info http://www.tomshardware.co.uk/forum/247146-29-heat-problem-systin-cputin
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
https://linustechtips.com/topic/249894-motherboard-overheating/#findComment-3426679
Figured it out, its definitely the north bridge, after opening the side panel and placing a desk fan next to it, temps dropped (by 50 degrees in 2 minutes :o)
Ordered a 120mm noctua, gonna ghetto mount one on there and make it look pretty. thanks guys.
https://linustechtips.com/topic/249894-motherboard-overheating/#findComment-3427149
86C? What motherboard do you have? That is one terrible design flaw.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/249894-motherboard-overheating/#findComment-3427159
If this was solved for you, could you please mark the answer that helped you the most as "Mark Solved" so that the thread can decrease in priority?
Thank you!
https://linustechtips.com/topic/249894-motherboard-overheating/#findComment-3427902
