NZXT H440 LED
Solved by W-L,
Ah..how do I connect it to power? sorry im new to building pcs. I connected the molex cable that came with the usb 3 and front headers to the psu already...there was one 3 pin connectors thats still not connected to anything. thanks for you reply by the way
No problem, just follow the wire that runs into the power unit so the 2 pins on the left in the photo, it should lead to a molex power and a small button on the back of the tower to turn it all on and off make sure that button is on and the board is plugged in.
