cpu cooler required
Solved by Jade,
Here you guys can have a look at the site i purchase it from
www.flipkart.com
@Jade please if you would could you look in there and tell me if any good cooler is available there.
And out of all the suggestions i could only find corsair cooler available and that too out of range...
And remember my case is CM 311 ELITE
TX3 Evo should fit in your case, and is 1630rs. Seems to be your best bet. Not much else I can point out there.
