Hello LTT community!
I'm looking for a power supply for my next build. It needs to be fully modular, 80+ Gold, 650-750W (enough for dual 970s) and not from EVGA (they're not available here). So far I've only found the Corsair RM series, which you don't seem to like. Thanks.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/
coolermaster v850 rm 650-850  or the silverstone strider gold
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421637
XFX XTR or Pro Series
Seasonic X series
Antec EDGE
Silverstone Strider
Superflower Leadex
NZXT Hale 90
Cooler Master V series
Corsair AX
FSP Group Aurum
Thanks, I'll look into them. Corsair AX is kinda expensive though...
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421668
Can you link us to where you're shopping? What's your budget?
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421681
Well, I shop at http://arvutitark.ee/ . The site is in Estonian, but I think you can figure it out with Google Translate. Budget is 160 euros.
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421691
Yeah I know, but sometimes you can only find a small variety :(
The RM series are not bad, they are just not up to the competition, specially on that pricepoint. But they are perfectly safe and efficient as any other good quality 80+ Gold.
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421720
M12II Evo 750w: http://arvutitark.ee/est/TOOTEKATALOOG/ARVUTIKOMPONENDID-Toiteplokid-PSU/Seasonic-M12II-EVO-Edition-M12II-750-Bronze-750-Watt-80-PLUS-Bronze-Certified-SS-750AM2-72270
Any reason why you'd need a gold rated psu?
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421761
Thanks. Would like 80+ Gold because I heard it's a good efficieny rating and anything higher isn't worth the extra cash. I've heard that SeaSonic PSUs have trouble screwing into cases....
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421784
There is nothing wrong with the RM series, its just that in most countries the EVGA SuperNOVA G2 PSUs are much better and for the same price.
Buy an RM750 with confidence if that is what is available where you live.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421786
Value in general goes down as you go up the chain of more efficient psus due to diminishing returns and marketing. I haven't seen anyone else have the issue with screwing in seasonic psus--or psus in general.
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421801
Heard of Carey Holzman? He stopped using SeaSonic PSUs because the screw holes didn't line up correctly. And I've had problems myself, when I changed the PSU on some old case to an S12II one hole wouldn't line up.
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421812
Yeah, I watch his videos. I haven't had any issues with psu holes lining up. You can just rma it if that is the issue.
https://linustechtips.com/topic/249502-need-a-fully-modular-psu/#findComment-3421922
