I was following steps to change / customize my windows 7 lock screen
one of the steps was to temporarily rename the authui.dll file found in C/WIndows/System32
unfortunately i got sidetracked by something else and didnt get around to pasting in the new authui.dll for the theme i wanted to install,
and i shut down my laptop before i completed the process
now my laptop boots into windows. but instead of the lock screen it now just shows me a blank black screen with the mouse cursor,
I typed in my password into the blank screen anyways just in case that would boot me into my desktop but it didnt....
I messed up, Im freaking out
Please help me LTTC
Thanks
* *** ** * * * * SOLVED * * * * ** * * * * * * *
SOLVED!
I plugged in my laptop's harddrive into my desktop
and was able to go into the Windows/System32 folder and rename the file back to its original name
and now it works once again
*phew*
Phenom II X6 1090T @3.6ghz , EVGA GTX 770 SC, 8GB Hyper-X ram, Adata SX900, WD Black, Corsair HX850, LG IPS234, Logitech G9x, Logitech X-230, Netgear R7000
https://linustechtips.com/topic/249367-help-screwed-up-authuidll/
Try pressing Esc or F8 during the boot process. It should bring a safe boot menu, one of the options should be to do a system restore via the "Restore PC to last known good configuration" or something along those lines. Feel free to ask any further questions if you need any more help.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
i pressed F8
"Last known Good Configuration"
but still the same result, blank screen with cursor
Hey @Whiskers, do you think you could help us out?
SOLVED!
*phew*
SOLVED!
*phew*
Ah good idea mate. Glad that you got it sorted. There is a lesson to be learnt out of all this isn't there, and I bet you know what it is too? ;)
