help with building a custom controller
Go to solution Solved by louddifference,
I know it's possible to build a switch box with momentary switches and have it interface to the computer via Arduino with some programming but that's where my knowledge ends, you'll need to know how to program the input and have it go via the USB or serial. Only thing that seems iffy is how the computer would read the input device as a command like on a keyboard.
ive found a pulse generator. it looks like its easy to set up and will do exactly what i want
so im buying a new hotas and i also want to build a custom controller with maybe 5 momentary switches.
like these:
and also some buttons.
what kind of controller will i need to buy? also what software would be best to set it up?
ive heard you can do it with an arduino but im not sure how to do that.
i want to make a smaller version of one of these but just switches and buttons
any help would be awesome
https://linustechtips.com/topic/249151-help-with-building-a-custom-controller/
Seems pretty complex. I don't see how you could use momentary switches because they're either on or off to complete a circuit. The ones on fan controllers increase and decrease the voltage.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
i dont mean a fan controller i mean to have this sitting on my desk and each switch is a keybind for games.
thats why im here
Just curious how's a pulse generator going to interface with the computer?
From looking it's used to test electrical components.
via usb. here the link.
http://www.desktopaviator.com/Products/Model_2120/index.htm
hoping its still available since the video i found it from is from 2009
im going to have to use toggles but its not a problem
Ah ok, it's an interface board that connects the buttons via USB, and they show how they interface it with windows, looks promising. I sure there are other sellers out there that also make interface modules like this, I would say try Amazon or Ebay first.
i couldnt find any on ebay. might check amazon but i have my doubts it will be there.
thanks
thanks
Hmm I would think there would be more of theses out there but the ones I'm finding are are for custom arcades setups to run on PC.
http://www.ebay.com/itm/PC-PS3-USB-ARCADE-CONTROLLER-INTERFACE-FOR-1-JOYSTICK-AND-12-BUTTONS-/271385985449?pt=UK_Video_Games_Coin_Operated_MJ&hash=item3f2fdd81a9
If you don't mind doing a bit of programming these are the Arduino libraries: http://arduino.cc/en/Reference/MouseKeyboard but note they only work on the Leonardo, Micro, or Due however there are custom firmwares for the UART to USB chip that are supposed to be able to get it working on things like the Uno: http://hackaday.com/2012/06/29/turning-an-arduino-into-a-usb-keyboard/ though I've never tried that before (the 32U4 chips are just too convenient even if they cost a little more).
When you get around to making it, could you please do a post on how you did it? I'd love to setup something similar for myself.
yes i was planning on doing so. i may order the controller on the weekend. there are a few i have to choose between.
ill take a look at that one. thanks.
i may want to get one with more connections because im planning to add a modular interface on the side so i could add another panel without buying another controller.
