Suddently my hard disk has become so slow: after the motherboard's logo remains a black screen for about 5 minutes, when i log in into windows the hard disk stay at 100% even if nothing is using it. I started Acronis Drive Monitor and it has a "warning" on Current Pending Sector Count. Can someone help me?
Thanks
post-153474-0-46252300-1415726358_thumb.
Sorry if my english isn't perfect
Gaming PC
CPU: Intel Core i7 4770K @3.50GHz Cooling: Corsair H80i Graphics Card: ASUS GeForce GTX 780 Motherboard: ROG MAXIMUS VI HERO RAM: Corsair 16GB @1600MHz PSU: Corsair AX760 SSD:Samsung 840 EVO 250GB HDD:Western Digital Black 1TB Headset: Logitech G930 Wheel Logitech G27
iMac Mid 2011
CPU: Intel Core i5 @2.70GHz Graphics Card: AMD Radeon HD 6770M 512MB RAM: 8GB @1067MHz SSD: Samsung 845 EVO HDD:Western Digital Red 2TB
https://linustechtips.com/topic/248784-wd-blue-problem/
Run a "chkdsk /f" command from an elevated command prompt.
it'll ask you (if this is your C drive) if you want to schedule the check for when you reboot, chose yes, and reboot your PC.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3411867
Download and run WD's Diagnostic Tool and see if the HDD is bad or not.
the pc is too slow, i have finished the chkdsk and now i'm waiting, I'm going to do something else until windows start
Gaming PC
iMac Mid 2011
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3412047
If you're still waiting, the chkdsk was unsuccessful, or the system is completely bogged down with infestation.
It's possible that your drive has partially failed.
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3412088
ok, windows has started. there should be some sort of log?
Gaming PC
iMac Mid 2011
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3412243
It should be found under
Control Panel > Administrative Tools > Event Viewer > Windows Logs > Application > Wininit
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3412277
when i try to open it says that "Service event log is not available. verify that the service is running"
edit: WD Diagnostics say this:
Gaming PC
iMac Mid 2011
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3412336
Hi there,
I'm sorry to say that but you need to backup all your data as soon as possible. It's a good idea to start with the most important files first. You should be able to copy all data in time if you are not using the HDD for anything else. The WD Data Life Guard Diagnostics Status Code 07 means that the drive is defective and you need to replace it.  The same goes for 102.  You can check the WD DLGD error codes list here:
There is a chance that it's not the HDD that's failing but the cable or the SATA port and I would try swapping those. But only after all the data is transferred to a different HDD.
You can check the warranty and start the RMA here http://support.wdc.com/warranty/ or contact live support http://support.wdc.com/contact/contact.asp?lang=en
Hope that helps.
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3417976
I just finished transferring all my stuff, later I try to swap port. it's strange because after it has loaded Windows everything works fine
edit: I changed port and cable, nothing has changed
Gaming PC
iMac Mid 2011
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3420407
But I did only the fast test, if I try the complete test can help a little more?
Gaming PC
iMac Mid 2011
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3433187
I don't think that the extended test could help in this case. It will just check the whole HDD sector by sector. It's good if you're looking for bad sectors. You can run it anyway, it shouldn't cause any harm.
Have you tried contacting the WD support guys?
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3466231
yep, I replaced it with a caviar black and an SSD. My wallet is crying :C
Gaming PC
iMac Mid 2011
https://linustechtips.com/topic/248784-wd-blue-problem/#findComment-3466266
