NZXT or Corsair
Tetters
All,
I am looking to replace my Chaser A31 with either a Corsair 750D or a NZXT Switch 810. I do like the very clean lines of the Corsair, but the design of the 810 is rather tasty too. They seem very similar interms of roominess and good, sensible design interally but what I am looking for is current owners pros and cons.
I will be running a custom water loop but nothing too wild ( one, maybe two 240 rads max), I currently have a Corsair H75 that will be in the case until the custom loop gets installed.
Both seem awesome cases and I am torn between the two ... the agony of choice!
Thanks
i5 4670k @4.2ghz / MSI Z87 G45 / EVGA GTX 960 SSC / Samsung  840 EVo SSD / WD Green 1tb HDD / Corsair H75 / Corsair Obsidian 750D / Corsair CS750M
I would personally go for the 750D after owning the Switch 810. Don't get me wrong, I've still got it lined up for another build, but I personally don't like the plastic front and top panels. They're very cheap looking and flimsy. Other than that the features are near identical.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
Custom watercooling loop - 750D definitely.
NCASE M1 i5-9600k  GTX 1080 FE Z370N-WIFI SF600 NH-U9S LPX 32GB 960EVO
I'm a self-identifying Corsair Nvidia Fanboy; Get over it.
Guys, Thanks so much for the quick responses, I do appreciate it. I think I will be getting the 750, it just seems to make the most sense.
Cheers
