Please help [Math]
Hold on...
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407411
7062.72 is what i got.
8000/(1+0.025/4)^(4* 5)  = P
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407431
I got $7062.72212049 (Rounded: 7062.72) but here is what i did:
8000=P(1+0.025/4)^20
How I got 4: compounded quaterly so 4 times per year
20: 4times*5years=20
EDIT: 0.025: 2.5%/100 (to get decimal)= 0.025
solve for P by calculating (1+0.025/4)^20 and 8000/Answer you got after calculating  (1+0.025/4)^20
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407432
use that photo math thing/
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407450
plug and chug, it's really easy
A  = 8000(1+0.025/4)^(4 x 5)
8000 is what you start off with
2.5% == 0.025 is the rate and it is compounded quarterly, so you divide by 4
raised to the time which is quarterly so 4, times 5 years
don't have a calculator on me, but plug this in and you will get answer
EDIT (yeah, it's not raised to 12 x 5, it's raised to 4 x 5)
I got $7062.72212049 (maybe wrong) but here is what i did:
Me too, I got the same result: 7062.72.
Edit: I need to practice my maths cuz on Wednesday and Thursday i have math exams, the first one (wed) is without calculator and the second one (thu) is with calculator. @OP if you have some trouble with your maths i will happily help you :D
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407455
Doesn't work.
This works. Thank you so much. I had no idea what I was doing wrong.
I was literally sitting here punching my desk because I had no fucking clue what I was doing wrong.
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407472
Doesn't work.
No problem. ;) Hope the next ones will be easier.
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407491
I got 7062.72.
P = ?
r = 0.025
t = 5
n = 4
8000 / (1 + (0.025 / 4)) ^ (4 * 5)
(10th grade)
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407495
Hopefully. I haven't had much luck all semester. Currently failing algebra.
Even though math can be hard sometimes, try to ask questions (to the instructor or the forum :D) for stuff you don't get as these calculations and most concepts come up over and over in math. Best of luck in completing the rest of the course! :)
https://linustechtips.com/topic/248431-please-help-math/#findComment-3407553
