3 case fans...
I'm getting the Zalman R1.
It has 3 fans pre-installed, one in the front and two in the back.
In Linus's video about air pressure it says to have positive air pressure to stop the build up of dust.
This is what I want but the case has two exhaust fans and one intake.
For positive air pressure should I move the top exhaust to the front or should I turn around the rear fan into an intake?
Or is there any other way to achieve positive air pressure?
https://linustechtips.com/topic/248330-3-case-fans/
Either would work. I'd move a fan to the front for intake.
https://linustechtips.com/topic/248330-3-case-fans/#findComment-3405843
