I amstuck on. My phone at the moment. W7 install disk stops on the choose language screen, there is no mouse cursor and my keyboard is u responsive.
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/248139-w7-install-problem-help/
Check your BIOS. Could there be some issue between your peripherals and the BIOS?
https://linustechtips.com/topic/248139-w7-install-problem-help/#findComment-3403126
I may have fixed it. The back port usbs didnt work whei ebtered the iso. Front ports work fine
 (\__/)
https://linustechtips.com/topic/248139-w7-install-problem-help/#findComment-3403145
How do i fix my back io ports though on usb
 (\__/)
https://linustechtips.com/topic/248139-w7-install-problem-help/#findComment-3403300
I am installing cd drivers to see if thatt solves the problems
 (\__/)
https://linustechtips.com/topic/248139-w7-install-problem-help/#findComment-3403563
Depending on the mobo manufacturer, the back usb ports may not be active until the drivers are installed. I've done repair on some computers running ASUS mobos and only two specific ports worked in BIOS but fine in the OS with the right drivers installed. So you may not need to panic just yet.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/248139-w7-install-problem-help/#findComment-3404628
My guess is that the back USBs are USB 3.0.
Windows 7 doesn't support USB 3.0 natively. You need drivers.
Check ASUS website for the USB and motherboard chipset drivers.
It's all perfect now. I just got my new parts down so I went away and installed them all. I accidental killed 2 of the 3 backups I had which is stupid but thank GabeN that I made 3 backups. Anyway it turns out that the USB 3.0 ports could only be used in the UEFI and not in any OS or bootable disc so I had to use the front USB 3.0 which worked for some reason. I downloaded all the new drivers and that fixed everything.
 (\__/)
https://linustechtips.com/topic/248139-w7-install-problem-help/#findComment-3404883
