Hi,I have problem with my mic volume that forces me to manually change the mic volume every time I turn on/restart my computer.
Lets say I have the volume at 80% and the boost at 20, if I restart the computer and try to use the mic the volume is really low(even though its a 80%-20), the only way to reset the sound to the way it should be is changing the volume and boost for any other value(lets say 50% with a 10 boost) aply the new values, go in again and change back to the 80+20.
At first I tought it was a mic problem but since them I changed mics 3 times and still ahve the same problem.
Does anyone know what the problem might be and how to fix it?
thx
https://linustechtips.com/topic/248033-mic-volume-problem-help/
