Can somebody help me make this cheaper while keeping the i7
http://ca.pcpartpicker.com/p/d9fnjX
Cpu: i7 4790k Mobo: Asus z97-A  PSU:Ultra Semi-Modular 850w SSD: Kingston 240gb HDD: Segate 1tb Ram: 2x8gb G.Skill ram GPU: Zotaz GTX 980 AMP! Case: Fractal Design Define R4 Windowed
https://linustechtips.com/topic/247766-new-build-help/
Get a GTX 970 and a USB wireless card. If you really want to keep the i7 then the drop from the 980 to the 970 will not be that bad.
As far as wireless cards are concerned, there isn't THAT much of a difference between a USB wireless adapter and a PCI-E one, unless your a hardcore gamer.
EDIT: It appears you have already bought the 980?
https://linustechtips.com/topic/247766-new-build-help/#findComment-3397814
. I already have the 980 forgot to mention that
https://linustechtips.com/topic/247766-new-build-help/#findComment-3397826
Are you Over Clocking?
Get a cheaper Mobo and Mointor
yupps
https://linustechtips.com/topic/247766-new-build-help/#findComment-3397835
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($348.89 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($32.79 @ DirectCanada)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($124.99 @ NCIX)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1866 Memory  ($84.98 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($57.98 @ DirectCanada)
Video Card: Zotac GeForce GTX 980 4GB AMP! Edition Video Card  ($0.00)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($64.98 @ DirectCanada)
Monitor: AOC i2267Fw 60Hz 22.0" Monitor  ($129.99 @ Canada Computers)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($36.99 @ NCIX)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($31.00 @ Vuugo)
Other: Case ultra defender 2 ($69.99)
Total: $982.58
Generated by PCPartPicker 2014-11-09 18:08 EST-0500
https://linustechtips.com/topic/247766-new-build-help/#findComment-3397873
Total: $982.58
dude thanks
https://linustechtips.com/topic/247766-new-build-help/#findComment-3397900
First thing that came to mind.
...that why i failed English class
https://linustechtips.com/topic/247766-new-build-help/#findComment-3397969
By watching too much Scooby Doo? That's a good enough reason in my book. :D
yup
https://linustechtips.com/topic/247766-new-build-help/#findComment-3397986
You could always consider doing what I am doing. That's for about a couple of months or so use the stock cooler that Intel provide with their CPU and then buy a water cooler when I have enough money. In the long term this saves money as you end up with a better system. You could also consider doing this with the peripherals if you can.
https://linustechtips.com/topic/247766-new-build-help/#findComment-3398233
okay
https://linustechtips.com/topic/247766-new-build-help/#findComment-3398242
