LEDs keep reverting to default color
By
aduman
in Power Supplies
in Power Supplies
Solved by Mod3,
I'm actually doing that, is it bad? They are controlled via an hardware switch on the front panel of the case.
That's the problem. The hardware cannot remember it's LED setting if it isn't powered.
It's not bad for your system, but it will cause the LED's to reset every time you plug it back in.
If you dont want to have to change the LED setting, just dont unplug the system. I know I'm being a bit blunt, but it's really the only option!
Featured Topics
1
Shadow1789 ·
Posted in Cooling3 -
7
3
1
9
6
4
