Recently i just started learning about building a custom pc and im planning to build a pc on a phanteks enthoo luxe case. Im planning to use the stock fans and im putting in another two 140mm fans as exhaust and all of the fans are connected to the pwm fan hub and that is where i have a problem.I have three 140mm fan on top of the case a 140mm fan at the rear as exhaust but only one 200mm fan as intake.
And so,
1. Will the case have a positive airflow?
2. How much air does a 200mm fan move.
3. How much air does other fan sizes move.
Thanks
https://linustechtips.com/topic/247454-help-on-positive-air-flow/
1. You should have equal or slightly positive airflow. This is ideal, however it depends on the airflow, by the sound of it you will have nagative airflow.
2-3.Depends, usually 200mm fans work on low RPM and smaller ones on higher RPM so the airflow depends on the type or fan and the RPM, you can usually get airflow information from the manufacturers website.
Find the specs about the 200m fan and I doubt that it will provide enough airflow as the 2 exhaust. Usually 200mm fans perform the same as 140mm fan in terms of airflow but the run at a lot lower RPMs and provide a lot less sound
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
There will def be negative
And so,
Thanks
Hmm, this is actually very similar to a couple situations for me, and I'm most likely building my main rig in the Phanteks case. It seems like you have more exhuast that intake, therefore you will have negative pressure. Positive pressure is what you want, I'm still trying to figure out the best fan setup for two cases I'm working on atm.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
With that config you will have negative pressure for sure. And I don't get why you would need as much exhaust anyway. You can easily remove one or two fans and still have it efficient enough. The 200mm fan in there has 110CFM at full speed. Depending on which fan models Phanteks is using as their case fans, you can have even three of those and still be on positive side by making them run slower than 200mm.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
