Upcoming Build: Mini-ITX case recommendations, please?
Solved by TheSLSAMG,
The PSU is overkill.
Well, you missed the entire point of the thread.
OP, The 250D is a solid, high quality case, as is the Node 304. I personally am not a fan of the Node's design or layout, so I would have to suggest the 250D.
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting0 -
2
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin ·
Posted in Displays2
