Best $1k Build
Solved by Stefanopolis,
Not so sure about the PSU, but maybe ask around if this is okay. It's a slight bit over your budget, but if you can deal with that and the small SSD capacity, good. Like I said, ask around to see if THIS is ok. http://pcpartpicker.com/p/pK8ZGX
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
