shall i fit cooler cooler master hyper tx3 hyper evo to my fx 8350 with two extra 120mm fans for overclocking games,because any technician cant fit cooler master 212 hyper evo in my place .money is wasted.
Hyper TX3 isn't a great cooler, but it will get the job done better then the stock cooler.
"Rawr XD"
https://linustechtips.com/topic/246045-about-cooling/#findComment-3377501
If you are looking for radiators go for the h100i. Great way of cooling your cpu and get great temps.
-Zinqs [-] i7 4790k @ 4.6 ghz [-] 2x EVGA Gtx 980 SC [-] Asus Maximus VII Formula [-] 16gb Dominator Platinum [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/Zinqs/saved/#savedbuild_1641021
https://linustechtips.com/topic/246045-about-cooling/#findComment-3377547
