Need help with a good case for this build
Phanteks Enthoo Pro
Phantkes Enthoo Luxe
Stay away from the H100i, it has a bad mounting problem. As well as noisy pump and buggy software.
Also, why a locked processor with Z motherboard and liquid cooling? Get the i7-4790k. If all you are doing is gaming, the i5-4690k is all you need.
Get an SSD. Its a must have nowadays, especially at your budget.
Buy a better PSU. You are overpaying for a poor quality PSU. The one I selected is excellent quality, and less expensive.
Here is a much, much better build:
PCPartPicker part list: http://pcpartpicker.com/p/F2zP99
Price breakdown by merchant: http://pcpartpicker.com/p/F2zP99/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($317.25 @ Amazon)
CPU Cooler: Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler ($74.99 @ Newegg)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($107.93 @ OutletPC)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($81.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive ($59.40 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($84.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card ($349.99 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Newegg)
Power Supply: Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($49.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($102.98 @ Newegg)
Total: $1324.50
Generated by PCPartPicker 2014-11-06 17:07 EST-0500
