Hey forum I want to upgrade my pc for about 250-300 dollars and am not sure what is the best thing to do my specs are as follows :
CPU - i5 2500k 3.30GHZ
GPU - gtx 550ti
Ram - 8GB
PSU - 800W
HDD - 500GB
MOBO - MSI ms 7680
Any tips and links will be very helpful thanks guys.
https://linustechtips.com/topic/245662-upgrade-need-help-please/
I would advise you to get a small SSD as a boot drive and to add a better GPU. You could also get a better motherboard (http://pcpartpicker.com/part/asrock-motherboard-z77extreme4m) and a better water or air cooler and do some overclocking beacause you do have a "K" chip.
https://linustechtips.com/topic/245662-upgrade-need-help-please/#findComment-3372135
What is your mobo and cpu cooler? It would be good if you overclocked a little.
You could wait a bit and get gtx 960 or whatever nvidia and amd releases in future.
Right now you can afford r9 290.
Would the gtx 960 be better than the R9 290 and what would the price difference be? Is there an estimated release date?
https://linustechtips.com/topic/245662-upgrade-need-help-please/#findComment-3372255
Upgrade the GPU to the r9 290
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/245662-upgrade-need-help-please/#findComment-3372297
I see a gtx 760 X2 is better than a R9 290 and for cheaper?
http://gpuboss.com/gpus/Radeon-R9-290-vs-GeForce-GTX-760-X2
http://pcpartpicker.com/part/zotac-video-card-zt7040610p
which  would be better?
X2 is two 760 cores on one gpu, the one you linked is normal 760 with 4gb of vram
its expensive.
https://linustechtips.com/topic/245662-upgrade-need-help-please/#findComment-3372559
