PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/245176-mirco-atx-am3/#findComment-3365532
Mine,
Gigabyte 78LMT-USB3
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/245176-mirco-atx-am3/#findComment-3365544
Could someone link me a micro atx am3+ motherboard that is good , and preferable more than £50. Not bothered what spec it has ect. I just need an upgrade. I can't seem to find any MICRO ATX boards that are good anywhere?
The only decent one is the Gigabyte GA-78LMT-USB3
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/245176-mirco-atx-am3/#findComment-3365549
GA-78LMT-USB3 Rev5.
Is usually around £40 on Amazon UK.
Good with quads and OC. OK for hex and safe with octo cores.
https://linustechtips.com/topic/245176-mirco-atx-am3/#findComment-3365588
