CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($319.00 @ PC Force)
Motherboard: Gigabyte GA-Z97M-D3H Micro ATX LGA1150 Motherboard  ($179.00 @ PC Force)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory  ($134.05 @ Aquila Technology)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($115.00 @ PC Force)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($647.00 @ Paradigm PCs)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($146.00 @ Paradigm PCs)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($149.95 @ Computer Lounge)
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  ($199.95 @ Computer Lounge)
Keyboard: Cooler Master CM Storm QuickFire XT Wired Slim Keyboard  ($153.00 @ Paradigm PCs)
Total: $2187.95
Generated by PCPartPicker 2014-11-05 21:46 NZDT+1300
So I need a case for all this consider I might change the mobo to a ATX so i'm considering a mid tower case. What i'm considering is the NZXT S210 elite with window. Also maybe a NZXT S340, since it looks similar to a H440, but because everything is overpriced in New Zealand I think i'll have to spend a bit less on the case since i've gone overboard already. One I need to ask someone is, can anyone find a NZXT S340 inside New Zealand?
https://linustechtips.com/topic/245028-case-for-first-build/
PHANTEKS ENTHOO PROOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO............................................
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3363721
http://nz.pcpartpicker.com/part/corsair-case-cc9011029ww
This is my choice of a MicroATX case, I would also buy the Fractal Mini R2. In my opinion you should change the SSD because of the read degradation the Evos have. I would change the monitor but I don' know the budget you have planed for this build.
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3363724
CPU Cooler: Deepcool GAMMAXX 300 55.5 CFM CPU Cooler  ($39.00 @ PC Force)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard  ($224.99 @ Mighty Ape)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($97.00 @ Paradigm PCs)
Power Supply: FSP Group 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($149.44 @ Ascent Technology)
Monitor: ViewSonic VA2349S 60Hz 23.0" Monitor  ($202.12 @ Aquila Technology)
Case Fan: Deepcool XFAN 120 44.7 CFM 120mm  Fan  ($9.74 @ Ascent Technology)
Total: $2317.72
Generated by PCPartPicker 2014-11-05 22:15 NZDT+1300
I changed the PSU and mobo to something that can handle SLI. Case is SPEC-3 from Corsair and 3 extra fans to keep everything cool and quiet. Changed the RAM to something cheaper. Changed the SSD and CPU cooler to more economical choices. Monitor is a couple of $ more but it's 1 inch larger (  ;)) and has a DVI connector.
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3363728
Those prices scared the shit out of me...
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($66.00 @ Paradigm PCs)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($215.84 @ Ascent Technology)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($129.00 @ PC Force)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($79.00 @ PC Force)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($629.00 @ PC Force)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case ($94.00 @ Paradigm PCs)
Power Supply: Cooler Master VS 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($139.00 @ PC Force)
Total: $2288.74
Generated by PCPartPicker 2014-11-05 22:28 NZDT+1300
"an obvious supporter of privacy"
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3363788
Total: $2317.72
you don't need the many case fans unless your case doesn't include them which most cases do, also deepcool don't make high quality products
u wot m7+1
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3363810
Total: $2288.74
Your profile picture makes it even better.
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3363857
Read degradation? Haven't heard about that before.
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3366324
Yeah there is some kind of problem with the Samsung Evos, but not with the Pros, I think. It's a problem where data that is stored for a long time on the SSD is red really really slow, like HDD slow.
This video gives a good explanation on what is this "degradation" I am speaking of.
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3366581
https://www.youtube.com/watch?v=GSrfOkr5hCc
Samsung released new firmware to resolve this problem?
http://www.samsung.com/global/business/semiconductor/minisite/SSD/global/html/pc/support.html
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3371548
Do you think the 840 is the best option?
We're getting so technical about things at this point that it's hard to say. I would do some research of similarly priced drives from Crucial, Adata, etc, and see the pros and cons of each and choose a drive for it's overall feature set, performance, problems, lack of problems, etc. Crucial MX100 and m550 are very good and about the same price as 840EVO and do not appear to have this problem.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/245028-case-for-first-build/#findComment-3377512
