Sorry for asking too much. Im supposed to buy a Powercolor Turboduo 260x but then I saw this Powercolor Fling Edition HD7850 2GB for just $10 more and a Powercolor HD7850 1GB for $10 less. Which one should I get? I suspended my purchase because of that. Hahaha. Also please dont suggest more cause the next cards are out of budget. Thanks!
https://linustechtips.com/topic/244480-gpu-help-again/
Okay thanks. New question. If a 265 is a 7850 rebrand which one will you chose if the 7850 is cheaper? :D
VRAM wise? 2GB all the way.
Oh I get it now. Go for the 7850.
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
https://linustechtips.com/topic/244480-gpu-help-again/#findComment-3354881
Both the R7 265 and HD 7850 use the exact same Pitcarin GPU with 1024 GCN cores. The R7 265 is clocked considerably higher however. If you intend to overclock your card both will perform the same. Otherwise the R7 265 will be noticebly faster.
https://linustechtips.com/topic/244480-gpu-help-again/#findComment-3355357
