Hi, I have a CX600M and I want to overclock both my CPU to 4.4 GHz (Intel Core i5 4670K) and my GPU (GTX 780 SC) should I upgrade my PSU if I am trying to overclock? I was thinking about getting this one if I do upgrade. http://www.newegg.com/Product/Product.aspx?Item=N82E16817438017
https://linustechtips.com/topic/243740-cx600m-for-overclocking-cpu-and-gpu/
I have my AMD FX-8320 OC'ed to 4.7 GHz  and my R9 270 OC'ed a bit and I've had no problems with it.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
I have seen a lot of people say that the CX600M is a low end PSU compared to everything else in my rig. Would upgrading the PSU help overclocking?
no, this psu is okay to handle both highly overclocked...its true that its a bellow average psu but its fine to use, go ahead!
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
It's low end in the sense that it's not 1000W+ or top of the range like most other things in the rig, but it doesn't need to be.
Be careful about adding another GPU in for SLI though, I won't recommend that with that PSU.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
no, its low end in the sense that its cheaply made and poorly built inside with 100% chineese capacitors....wattage has nothing to do with it...there are some 450w psu that are very high quality.
