I have this card: http://pcpartpicker.com/part/xfx-video-card-fx775aznp4
It is currently in a low-usage family computer (With an i5, it doesn't really need a graphics card). Would it be possible to get a similar card and crossfire it and get better performance than a GTX 650ti (another card I own)? Looking to run modern games at sub-1080p resolution. I assume the limited 1gb vram on both cards would cause some bottlenecking, but what do you think is the best option? It is going to be a gift for a friend. (Who has an AMD A8 computer, eh).
Thanks!
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/243119-help/
You can use another HD 7750 in Crossfire with that card, the performance would be about the same as a GTX 650ti, not really much better and micro stutter might be noticeable.
IMO you'd be better off using a single better GPU.
"Everybody wants a happy ending, right? But it doesn’t always roll that way." - TS
https://linustechtips.com/topic/243119-help/#findComment-3330569
I guessed that, I will just save the 7750 for a HTPC build (since its a hell of a card).
The Grey Squirrel
https://linustechtips.com/topic/243119-help/#findComment-3330581
