So when i go to the cpuz this is what is there
are the clocks right ??
| Case: Cooler Master Elite 371 | Cpu: i5 4690K @ 4.20 GHz | Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z97 Gaming 3 |
 | Gpu: Gigabyte G1 Gaming GTX 970 4GB GDDR5 | SSD: Crucial MX100 256 GB | HDD: Samsung 128GB Ram: Kingston 8GB DDR3 1333MHz |
| Screen: Benq XL2411Z | Mouse: Logitech G 403 | Mousepad: SteelSeries QcK+ NiP Edition | Keyboard: Steelseries 6GV2 | Headset: Kingston Hyper X Cloud |
https://linustechtips.com/topic/242674-gtx-970-questions/
540 is a weird frequency to clock down to. Download GPU-Z instead and show us a screenshot of that.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325281
Try out GPU-Z.
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325295
Try out GPU-Z.
540mhz seems really low isnt the clock supposed to be around 1.1GHz which if i remember right that should be what around 1100mhz
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325304
The GPU-Z screenshot looks much better.
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325307
i didnt touch anything  just got in the computer, where do i get the boost turned on??
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325313
It's part of NVIDIA's technology. The card will automatically boost up when the thermals and power limitations permit it to do so.
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325316
it whines when i run 3d mark ehh :c
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325356
That's nothing to worry about. It's annoying, but it happens.
https://linustechtips.com/topic/242674-gtx-970-questions/#findComment-3325361
