I was assigned the task of implementing a javascript-based chart onto a website. My problem is, i have little knowledge of how JavaScript works.
We have tried using everything from Google's developer resources to d3-charts, and i mean EVERYTHING. I have searched so hard for this stuff that my "Google Now" feed is nearly exclusively suggestions on line-chart content.
As much as i would rather not resort to it, i may have to learn JavaScript and code it myself. Luckily, the chart he would like is super-simple.
HERE is a image my boss threw together in photoshop of what he would like it to look like. I can manage everything except for the chart in PHP, so don't worry about the numbers.
So, does anyone know a good place to start? I need this done sometime this week if possible.
1: There can be NO guide-lines
2: There can be NO key/legend
3: There can be NO labels on either H or V axis
4: When a user hovers over a data point, they need the x&y data
~Judah
https://linustechtips.com/topic/240702-stupid-simple-javascript-chart-help/
I've used Rickshaw the past with a lot of success. It's built on top of d3, but makes interactive charts a lot easier to digest.
Take a look at http://code.shutterstock.com/rickshaw/ and specifically http://code.shutterstock.com/rickshaw/examples/formatter.html which seems to be very similar to what you're after (though with only data set).
In the end might be more worth yours and your bosses time to buy something pre-built: http://www.highcharts.com/products/highstock
it runs $90 but it is free for non-commercial so you can make sure it fits your needs before purchasing.
HighCharts is great, but it's still only as "pre-built" as Rickshaw, Google Charts, or any other charting library. It simply provides a nice API to do what you want with, and that still requires at least some basic JS knowledge.
Chart.js is another simple library I've used in the past, though I still find Rickshaw a lot more flexible. http://www.chartjs.org/docs/
I don't know how to do this, but I'm going to follow because I want to implement something like this on my site for downloads.
You're more than welcome to throw me a PM if you'd like any assistance.
