Need help
Go to solution Solved by Oxide_44,
It has a better feature set and more on-board options and will probably be more reliable. Graphics card can be added later if he decides to play something that needs more oompf. Could still build a system for cheaper, but yeah as far as pre-builts go, that should be a pretty good option.
So my friend is going to buy a pre-built (-_- yeah I know, I tried to convince him otherwise) and I was wondering if the one I picked good value for the money
http://www.pcworld.ie/Mobile/Product/hp-pavilion-500326na-desktop-pc-black-and-silver/318275/307#ctl00_ctl00__nestedContent__mainpageContent_ProductFamilyDetailsView1_liProductDetails
He said he was going to do some light gaming on it like minecraft, car mechanic simulator, etc. My question is the a8-6500 + r7 240 good enough for the said gaming. I wasn't sure where to post this so please forgive me! I think he has a 1280x720 monitor if thats relevant xD.
Thanks in advance :)
https://linustechtips.com/topic/240685-need-help/
So my friend is going to buy a pre-built ( -_- yeah I know, I tried to convince him otherwise) and I was wondering if the one I picked good value for the money
Last time a friend did that I flat out told him he's on his own.
But, yeah, for minecraft and light simulator, that will work.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/240685-need-help/#findComment-3299436
I mean, it'll work, but damn is it over priced.
I could be very wrong
https://linustechtips.com/topic/240685-need-help/#findComment-3299468
That setup should be ok, but I would advise against a HP. The price of those are way too high, and upgrading those models are a no-go. Newer HP pre-builts are also not exactly built with quality in mind these days either. For $500 you can probably find a better pre-built.
Main Rig "Bishop": Proc:i7 4790K, Mobo: EVGA Z97 Classified, RAM: G.Skill Sniper 16GB @2400Mhz, Case: Corsair Air 540, Cooling: (4) AF120mm (2) AF140mm Corsair H110, PSU: EVGA G2 1000W, SSD: Samsung 840 EVO 250GB, HDD: WD Black 2TB
https://linustechtips.com/topic/240685-need-help/#findComment-3299483
Wow.   That's over $600.   There's a current thread where some one asked for part recommendations for his friends $500 budget that has better parts than that HP.
There are some advantages to a manufactured computer, but I hope the OP's friend realizes the trade-offs.
https://linustechtips.com/topic/240685-need-help/#findComment-3299519
Do you recommend any good manufacturers?
https://linustechtips.com/topic/240685-need-help/#findComment-3299530
I know right! I tried to convince him but he wouldn't listen to me.
https://linustechtips.com/topic/240685-need-help/#findComment-3299547
If I were to buy a manufactured computer again, it would probably be a notebook.   Would he like one of those?    Integrated Intel HD graphics really isn't all that bad (I think it's up to 5000 or 5200 now) or maybe one with an AMD APU.
https://linustechtips.com/topic/240685-need-help/#findComment-3299569
Asus makes pre-builts, and they are not half-bad. Honestly anything with a CPU will run what he wants to run. My advice for him is to invest in a cheap prebuilt (A6 or Intel i3) and just shell out some cash for a non-powered graphics card;
http://www.amazon.com/gp/product/B00ILALU28/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00ILALU28&linkCode=as2&tag=jayz05-20&linkId=OKXUCWGKPJSZUPN5 <--- This would be a good option for a pre-built.
https://linustechtips.com/topic/240685-need-help/#findComment-3299573
He specifically said he wants a desktop though :/
https://linustechtips.com/topic/240685-need-help/#findComment-3299606
Hmm Im pretty sure my friend's parents want a complete pre-built and are not willing to buy computer parts to install. He is quite stubborn :/
Should I look for an asus pre built?
https://linustechtips.com/topic/240685-need-help/#findComment-3299627
Uhhh, for the 5 minutes it takes to put a card into a slot I'm not sure what the big deal is on that, but ok.
And yeah I would say ASUS would be a really good option.
https://linustechtips.com/topic/240685-need-help/#findComment-3299690
What do you think of this?
http://www.pcworld.ie/Mobile/Product/asus-m32bf-desktop-pc/318287/307#ctl00_ctl00__nestedContent__mainpageContent_ProductFamilyDetailsView1_liProductDetails
https://linustechtips.com/topic/240685-need-help/#findComment-3299772
https://linustechtips.com/topic/240685-need-help/#findComment-3299788
Thanks so much for your help :)
https://linustechtips.com/topic/240685-need-help/#findComment-3299846
