ssd help
Go to solution Solved by Samfisher,
Here you go :
http://www.thewindowsclub.com/change-default-program-files-directory-windows
But be warned, messing with the Registry can mess your PC up if you do it wrongly or modify other values accidentally.
Hi i have a ssd with my systems os on it and i also have a hard drive for games and things like that
but the problem is when i got to install thing i keep on having to say save the the hard drive
what i wanted to know is how do i have the same config but have the ssd locked so you cannot download anything on it or export anything off it so potentially locking it just using it as a boot drive and nothing else
thanks for future replays
https://linustechtips.com/topic/240336-ssd-help/
Here you go :
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/240336-ssd-help/#findComment-3294837
