Best Cooler $40
Solved by kei7t9,
Normally I would recommend Hyper 212 Evo. Max OC though is at 4.4 after that you need something better.
Alternatives are
Phanteks U-Type Dual Tower Premier CPU Cooler Black Edition
Notua NH D14
Enermax ETS T40 BK
EVGA ACX CPU Cooler
If you wanna stretch the money a wee bit further : Cryorig R1 Ultimate (currently running this cooler on a 4670K at 4.5 Ghz. This cooler can efficiently cool a 4.4 at 1.224 Max temp 58/ 4.5 at 1.26 Max Temp 67 / 4.6 at 1.30 Max temp 71 Although this is with a de-lidded 4670K + CLU.
