850 pro cables
Go to solution Solved by XTankSlayerX,
SATA Power and SATA 6 GB/s data cable...
What cables are needed for Samsung 850 pro?
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
https://linustechtips.com/topic/239991-850-pro-cables/
SATA Power, and Data Cables.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/239991-850-pro-cables/#findComment-3290662
Thank you guys!
https://linustechtips.com/topic/239991-850-pro-cables/#findComment-3290674
You obviously need Samsung branded sata6Gbit PRO cable for your shiney new ssd :D :D :D
/s
What others said :)
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
https://linustechtips.com/topic/239991-850-pro-cables/#findComment-3295951
