pygame.init()
display_width = 800
display_height = 600
rgb mean red green blue
black = (0,0,0)
white = (255,255,255)
red = (255,0,0)
green = (0,255,0)
blue = (0,0,255)
gameDisplay = pygame.display.set_mode((display_width,display_height))
pygame.display.set_caption('Race Craze')
clock = pygame.time.Clock()
carImg = pygame.image.load('mothership.png')
def car(x,y):
    gameDisplay.blit(carImg,(x,y))
x = (display_width * 0.45)
y = (display_height * 0.8)
crashed = False
while not crashed:
    for event in pygame.event.get():
        if event.type == pygame.QUIT:
            crashed = True
    gameDisplay.fill(white)
    car(x,y)
    pygame.display.update()
    clock.tick(60)
pygame.quit()
quit()
It says that is can not open "mothership.png" I have the file on my desktop. Please help?
RIG:  CPU: Intel Core i5-4690K CPU Cooler: Corsair H80i Motherboard: ASRock Fatal1ty Z97 Killer ATX Memory: G.Skill Ripjaws Series 8GB Storage: Seagate Barracuda 1TB Internal HDD SSD: Samsung 840 Series 120GB 2.5" SSD Video Card: Zotac GeForce GTX 970 4GB Video Card Case: Corsair 780T PSU: NZXT HALE82 850W 80+ Bronze Monitor: LG 34UM95-P Keyboard: Steelseries Apex Keyboard Mouse: Razer Taipan Mouse Mat: Razer Vespula Sound: Cyber Acoustics CA-3090, Corsair Vengeance 2100 :  1998.40 Euro
https://linustechtips.com/topic/239881-python-pygame-code-help/
You have to place the image in the same directory where your porgram.py file is saved (the file name of your program).
Else you have to show the path to the image. Like 'C:\Users\username\mothership.png'.Or what ever the path for your image is. You can find it by right clicking on the image and going to properties and looking for 'Location:'.
Hope that helped.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289480
Hope that helped.
How do I place the image in the same directory?
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289531
Well were did you save your program file? Go to the desktop right click and click copy. Then go to the file you saved your program in,right click, and hit paste. Now the image is in with your program file.
If you don't know what windows directories are I suggest YouTubeing it for a fast answer.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289581
When my script with my code opens, it does not open with IDLE it opens with textedit where I can not run the code. Also when I paste it, it just goes next to the script.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289614
Is it saved with .py as the extension? I know you can use cmd to run your script but I'm not good with cmd.
Done, but the image still won't go in the file. It just goes on top of it.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289657
If the file is saved with a .py extension and you get a black box flash on the screen when you double click it that means there are errors. Right click your program file and hit click edit with IDLE. Hit ctrl + F5 to run it and it will show your errors.
There is no black box, it just won't let me put the image in the script file.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289674
It still won't work. I run it and it still says cannot open the path to image
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289700
You can't put it in the script file. You put it in the folder. Are you administrator? Is there an error when you try to paste it in?
It is already in the same file, but it still won't work.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289705
Did you include the path cause if it is in the same folder as the script file you don't need to provide the path. The way to show the path may be wrong the way I showed you. Just try it the way you had if first.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289732
It is in the image! But the background is all black, how do I fill it with white and how do I change the position?
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289755
Also did you import pygame? Need to do that and import sys. Than down at the bottom where it say quit(). Get rid of that and put in sys.exit()
Done, but my image is all the way down where I can not see it, how do I make it where it is in the middle? And how do I change the background to an image?
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289780
Try:
x = (display_width/4)
y = (display_height/4)
One more thing, how do you change the background to white? Or maybe an image?
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289818
To add an image bacground try:
add
bgImg = pygame.image.load('mothership.png') or whatever the image name.
add
gameDisplay.blit(bgImg(0,0)) Put this code between car(x,y) and gameDisplay.fill(white)
For background color not sure why your program isn't displaying white already.
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289870
add
add
It says this :
Traceback (most recent call last):
  File "/Users/Livio/Desktop/Project 24/8bit come on.py", line 37, in <module>
TypeError: 'pygame.Surface' object is not callable
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3289921
Thank you so much! it helped me alot!
https://linustechtips.com/topic/239881-python-pygame-code-help/#findComment-3290823
