Laptop problems
Go to solution Solved by Altecice,
Thats going to need a DC jack replacement. Can be quite expensive to do at a repair shop. Just make sure you get it done correctly.
I have a buddy who bought a second-hand laptop and it has a charging problem, The Plug won't charge the battery and the adapter is loose inside the casing
CPU: i7 4770 GPU: GTX Asus 760 CASE: Zalman Z11 Blue COOLER: CoolerMaster Hyper 212 STORAGE: 2TB Toshiba Hard Drive 120 GB SSD
https://linustechtips.com/topic/239588-laptop-problems/
