Go try some out at a local furniture store. Or check second hand stores
https://linustechtips.com/topic/239582-chair-help/#findComment-3285201
There's nowhere in Georgia with chairs on display that you can actually sit on? Here in Canada we have a store called Staples which sells a ton of office supplies, computers, desks, chairs, monitors etc...all inside a warehouse type building.
https://linustechtips.com/topic/239582-chair-help/#findComment-3285220
Staples sells desks and chairs in their stores too in the US...., it's just not Canada that applies that.
https://linustechtips.com/topic/239582-chair-help/#findComment-3285253
I wasn't even aware Staples was in the US.
https://linustechtips.com/topic/239582-chair-help/#findComment-3285274
Well I live in bum fuck Georgia and there aren't really any furniture stores around. I'd basically have to drive about 45 minutes to get to an actual city.
https://linustechtips.com/topic/239582-chair-help/#findComment-3285303
IKEA Markus is what I have.
It is not super expensive, very comfortable and has some "support" for your lower back.....dunno know how to explain that. So it is actually pretty much a nice ergonomic, comfortable chair. ;-)
I know IKEA makes crappy products, but it really depends on what you buy. Some things are cheap in every ways, some things are actually good value.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/239582-chair-help/#findComment-3285319
I really need to get a new chair badly. I'm looking at no more then $150. I thought about a dxracer but I can't drop $350 on a chair right now. Any help would be appreciated. Thanks.
there is a chair at Ikea that has a headrest like a DXRacer and is about 169 ish. Ill link if you are interested!
https://linustechtips.com/topic/239582-chair-help/#findComment-3288392
I suggested the same chair above. It is actually very good.
https://linustechtips.com/topic/239582-chair-help/#findComment-3327468
