Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
true,false but number 3. are those dot products or just multiplication signs? f(g) and g(f) should be the same, not sure if f *dot product* g and g *dot product* f would be though. Been a while since I have done dot products. But I assume they are just multiplication signs, which should make it true...
I hope..... lol.
it's f(g) composite function
ah, i think that is false in that case. But I haven't done that type of math in years :/
multiplication signs are filled in dots. these are open circles
it means f OF g, meaning you put g(x) into f(x).
basically f(g(x))
Thanks , Did pass the 80% :D
