link?
it might be a limit based on the amount of 3.5" drive bays
http://www.senetic.com/product/704941-421
There are 4 drive bays, i could fit 4x6TB WD REDs in there, what prevents it from accessing more than 8TB?
You know theres this thing called the 'quote' button right?
People get your message when you reply using the quote.
Yeah it seems lie the 8TB is their maximum capacity based on 4x 2TB drives, but now there are much larger drives so im guessing you can fit over 8TB. You might want to contact the company and send them an email to make sure though.
Sorry, still new to the forum. Thanks for the help
Youre welcome :)
Rated capacities are probably just the biggest hard drives on the market when the product was released, and/or when the spec sheet was written up.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
So I bought a hp microserver and in the specifications on a website it says
Maximum storage capacity8  TB
There are a few possibilities. One, as mentioned, is that the number
is simply based on the amount of HDD slots and the largest capacity on
the market when the server comes out (which seems to be the case here
since apparently you can go above 8 TB).
However, there are also SATA/SAS controllers which can't address HDDs
larger than 2 TB correctly, in which case you couldn't get around that
limit without using a different controller. For example, I have a server
with a motherboard from the LGA1366 era, and the onboard SAS controller
has this limit, so I've needed to buy additional SAS controller cards
in order to be able to use HDDs 3 TB and larger.
Lastly, the manufacturer could have decided to be a dick and locked the
thing down to prevent people from using larger HDDs. Not sure if that
is actually ever done, but I wouldn't be surprised if so.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
