hey linus community i am going to be making a custom water cooling loop for my pc. I will be using a gtx 980 and a Intel 5930k and a 780t case by corsair. I would like 2 radiators at least 240mm each. Could you make a list of parts that I can use for this build. Just message me if you need to know any components or what I would prefer.
Thanks
Wolffangs147
Its when dragons have so much sex that the cpu cant handle it
https://linustechtips.com/topic/239036-water-cooling-components/
i know you aren't asking for this, but why are you buying a 5930k over a 5820k?
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/239036-water-cooling-components/#findComment-3278169
If you are building a custom loop, you should be able to make your own loop. It is an expensive process and should be done by yourself :P
($500-$1000 expensive)
I would recommend being a master at watercooling before purchasing. Singularity Computers on YouTube is a good place to start.
https://linustechtips.com/topic/239036-water-cooling-components/#findComment-3278170
Thanks for your help I'll look for some now
https://linustechtips.com/topic/239036-water-cooling-components/#findComment-3278327
Thanks
Wolffangs147
Have a look at this setup. EK @ PCCG Only thing I don't like about it is the DDC pump. But thats only cause I'm a D5 fanboy....
You may need to get some extra coolant.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/239036-water-cooling-components/#findComment-3278334
Thanks
Wolffangs147
Would definity recommend the 5820K, unless your going to be running quad sli or heaps of expansion cards. Save some money for the awesome watercooling stuff.
Check out PCCaseGear, they have got a massive range of watercooling parts and they are in Australia to cut down on shipping.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
https://linustechtips.com/topic/239036-water-cooling-components/#findComment-3278408
