Hey guys ive been thinking its time to upgrade my 7970, now i love AMD always have but with my 7970 came a common 2d bug where your screen would jump every now and then on 2d applications including browsers. Was not impressed seeing as tho I had spent alot of money on it. Thinking it was PSU also upgraded that it came down to adjusting the 2d clocks my self like alot of other people who had this problem, ok with that said im thinking of going back to green team havnt been with them since my G-force 4 ti, The 970 looks very promising with its price tag. What would you guys do?
CPU- I7 7700K @ 4.4Ghz, RAM- 32 Gig Hyper X @ 2800 mhz , GPU - GTX 1080ti Strix 11gb , MOBO- Asrock Fatality Z270 , SSD :Kingston Hyper X SSD Fury and Samsung 500gig
https://linustechtips.com/topic/238964-970-or-keep-my-7970/
i would personaly keep the 7970 unless it is unbearable until a gm200 part aka 980ti 1080 for nvidia or amd  390 or 390x comes out
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277224
I dont see my self going the 780 or 980 I have never spent that much on a card hehe. But yeh waiting to see what red team can punch out would be a wise move I suppose.
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277235
I was saying that because when they come out there will be the regement of price cuts.
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277258
Very true :D
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277270
Id wait. Unless there's a certain game you need more performance in.. I'm in the same boat with a 7970.I almost splurged for the 970 but thought about it and there's currently no game I play that I cant run perfectly fine. I'm holding out for the new AMD offerings.
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277306
Why would you want to go from 7 970 to a single 970?
Seriously tho, your current card is fine. I would only change if you're really concerned about power consumption. Or wait for amd and see what they release.
This caught my eye is all.
http://gpuboss.com/gpus/Radeon-HD-7970-vs-GeForce-GTX-970
And lower power consumption is always a good thing :P
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277325
I'd go with the 970.
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277362
it i a n innacurret source do 970 vs r9 280 as that is your card it wil bet it but once amd comes out with a competitor the 980 will probably go to 400usd
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277367
If I understand correctly you've fixed the 2D issue, then?
Provided its working fine, I wouldn't bother upgrading an HD 7970 right now, unless you're planning on moving to a 1440p monitor or something. And never buy based on brand name, buy the better product in your budget. But yeah, the GTX 970 is the best choice for its price at this time.
https://linustechtips.com/topic/238964-970-or-keep-my-7970/#findComment-3277459
