Finding a monitor of a specific size
Go to solution Solved by sabot,
Some 30 in monitors have this resolution: http://www.newegg.com/Product/Product.aspx?Item=N82E16824260132
 2560 x 1600
There may be some cheaper 27in ones with the same resolution, but these monitors will look so much better than your 20ins.
Hi, so i currently have 3 Samsung p2050 monitors in landscape mode. I usually have IM/twitter open on one and often keep webpages open on the other. My plan is to switch the two end ones into portrait mode and get a larger middle monitor.
However, i need them to all be the same size. I used to have it that the monitors were different sizes and the screens didnt line up (drove me crazy) so this is a requirement for me.
These are the dimensions of my current monitors. The resolution is 1600x900.
When looking for a new one do i just need to look for one which has a 1600px height? or does that not correspond to the actual size of the monitor? Do i need to search for the same pixels or the same screen height?
I use the computer for productivity and gaming.
Lastly can anyone recommend a website that i can compare lots of different monitors by the criteria above?
Many Thanks!!
https://linustechtips.com/topic/23868-finding-a-monitor-of-a-specific-size/
 2560 x 1600
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
Yes I believe so!
A dell u3011 should be really close but probably not an exact match. The 1600 x 1200 dell monitors are the only ones that match its height perfectly I believe.
i7 4770k, 16GB Corsair Vengeance
Gigabyte z87, Phanteks Enthoo Primo
7970
Okay, then that is your best option. If your problem is solved, make the answer that helped you best as solved.
