start by buying 100 of each top tier video card from the major manufactures (ASUS, EVGA, PNY, Gigabyte, MSI, Powercolor, Sapphire)...
Then when your done just raffle them off to the LTT community.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
Perhaps research components used in manufacturing graphics cards; how/why they're implemented and potential reasons they can fail.
  • Capacitors, chokes, other electrical componentry failing over time
Cooling fans failing / defective (not spinning)
Overheating (again, defective cooling fan, poor system ventilation)
User error (mishandling, damage from electro-static discharge)
Simply a defective product right from the factory
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
